Post processor - how to view only specific part water by 'age of fluid' etc
Old   August 20, 2015, 07:30
Default Post processor - how to view only specific part water by 'age of fluid' etc
Sean Petley
s.petley is on a distinguished road
I'm looking at the water flows in a Pelton casing, however to get the water jet to initialize I let run for a number of timesteps before it interacts with the bucket, therefore this water is present in the casing when I visualize an isosuface etc.
I was wondering if there is a way to get rid of this water by only looking at the isosurface starting with water from 0.05 seconds say.
I've read that I could do an 'age of air' type calculation, however this is implemented in pre, I wonder if there is an alternative so I don't have to run the simulation again.
Kind regards,
Sean
s.petley is offline   Reply With Quote
Old   August 20, 2015, 18:20
Can't you just look at the simulation at a time step far enough from the start that the startup transient has gone?
But to answer your question: I cannot think of a rigorous way of doing this in post processing only. You could put streamlines on the inlet that only last a certain amount of time - but I can't see how to then convert this into the water region which is new and discard the old stuff.
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 04:03
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 03:53
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 15:34
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
