CFD-Post axial pump torque
Old   October 15, 2012, 07:48
Default CFD-Post axial pump torque
m4D
m4D is on a distinguished road
Hello.
An axial pump problem was solved (inlet, impeller-archimeds screw, outlet; BC in: total pressure, BC out: mass flow). The resulting pressure rise is comparable with experimental values. Now I need to calculate reactive moment (torque) on the impeller from fluid for further calculation of efficiency of the pump. I tried to use "function calculator"->torque, then selected blade's side surfaces (or hub's cylinder, or shoud's cylinder, etc.) but the result is always zero about all axes. What am I doing wrong? How to calculate reactive impeller moment correclty?
edit1: no "turbo" macros were used in pre-processor, so can't use them in cfd-post
Thanks in advance.
m4D is offline   Reply With Quote
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 05:00
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 02:46
CFD post processing techniques & streamlining klk Main CFD Forum 0 October 19, 2010 07:37
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 09:29
