CFX solver configuration for multi core processor
Like Tree2Likes
  • 1 Post By david.pasquale
  • 1 Post By ghorrocks
Old   December 26, 2012, 10:18
Smile CFX solver configuration for multi core processor
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello everyone,
I have intel core i7-2630QM CPU @2.00GHz Processor with 8GB of RAM for running local parallel run what is the maximum number can i set for partitions
thank you
sunilpatil is offline   Reply With Quote
Old   December 26, 2012, 10:27
Sixkillers is on a distinguished road
I would say 8, because your processor has 8 threads (http://ark.intel.com/products/52219/...up-to-2_90-GHz)
Sixkillers is offline   Reply With Quote
Old   December 27, 2012, 05:48
How many parallel licenses do you have? That be the actual limit you have.
Assuming you have lots of parallel licenses - I recommend you do a benchmark study against number of CPUs. You will probably find that beyond 4 processes the speedup factor drops right off, and the 7th and 8th process may well make the simulation slower than 6 processes. These are just my guesses, so do the benchmark on your machine to find out for sure.
Old   December 27, 2012, 06:14
Thumbs down
David
david.pasquale is on a distinguished road
I totally do not agree..the maximum number of partitions has to be equal to the max number of cores of your machine...intel hyper threading is only a virtual stuff made for low load applications. In fact cannot help for very intensive calculations like cfd applications
Whitebear likes this.
david.pasquale is offline   Reply With Quote
Old   December 27, 2012, 06:23
I did not look up the specs of that CPU - David is correct - if it is a 4 core CPU then the 4 virtual cores from hyperthreading will not help at all and should not be used. But if you do a benchmark sweep of different numbers of cores like I recommended you would find that out for yourself
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
CFX 11, solver Debabrata CFX 1 June 16, 2008 21:52
cfx solver error sandhesh CFX 3 June 6, 2008 10:13
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
