December 28, 2012, 16:57 |
Problem with meshing, double pipe exchanger
David Lopez
Rep Power: 13 |
Good afternoon, the meshing in ANSYS ICEM-CFD. in detail mesh, Set Use Automatic Tet Inflation from None to Program Controlled. and I throw these warnings
* Pre-generation layer is stopped inflation Because of side face limitation, proximity collisions and quality. * Pre-inflation failed with non prism mesh generated, please check the attachments on the faces inflation. * if anyone can help me with this. thanks |
December 28, 2012, 17:18 |
now I have this problem
David Lopez
Rep Power: 13 |
now I have this problem friends
"CFX-Pre Application Error ERROR Syntax error: %s parameters should have the format: load" What does that mean? |
December 28, 2012, 20:52 |
Chris DeGroot
Rep Power: 17 |
It sounds like you are having some fundamental issues setting up cases. Have you gone through the CFX tutorials and do you know how to mesh in ICEM? I can't help with the information you have posted. You will have to give more specifics of what you are trying to do. For the meshing problem, see the ICEM forum.
December 29, 2012, 12:08 |
David Lopez
Rep Power: 13 |
Thanks friend, I made several simple cases but had never made that mistake. I will review the help of ICEM and will write to see if I can help someone who faces the same problem.
Greetings from Venezuela. |
[ANSYS Meshing] Problem of Meshing a orifice within a very thin pipe | justeyong | ANSYS Meshing & Geometry | 0 | December 8, 2012 15:37 |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 10:14 |
[GAMBIT] double pipe heat exchanger with helical fin around inner tube | mozafarie | ANSYS Meshing & Geometry | 5 | November 7, 2012 05:02 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
