Home > Forums > CFX
rotating and vibration setup
Old   January 30, 2013, 10:32
Default rotating and vibration setup
liuzexiang
liuzexiang is on a distinguished road
the simulation is as follow:
the model contains a tank and a tube tool. the fluid flows along the tube tool into the tank. the tube tool rotates and vibrates immersed the tank. i just simulate the rotating and the vibration respectively. the rotating tube tool is setuped as immersed solid. when doing the vibrating tube tool simulation ,i just use the fluid model and set the model as mesh motion. the cavitation model is set in these simulations. so both the two simulations were solved respectively, the results were obtained. but i found that the gas.volume fraction at the tube tool bottom and the tube tool side is approximate 1. i can not understand why the gas.volume fraction is so big. i just set the inlet pressure is 500000Pa, the saturation pressure is 3754Pa, the surf.tension.coff is 0.08Nm^-1.
liuzexiang is offline   Reply With Quote
Old   January 30, 2013, 10:38
liuzexiang
the contours about solver pressure ,fluid.velocity and gas.volume fraction are as follow:
anothe question: what is the difference about the total pressure, pressure, solver pressure;
thank you !
Old   January 30, 2013, 16:41
ghorrocks has a spectacular aura aboutghorrocks has a spectacular aura aboutghorrocks has a spectacular aura about
Your images are not readable. Please post readable images. Also include a drawing for what is rotation and what is vibrating.
Thread Tools
Trackbacks are On
ANSYS Workbench - How to obtain vibration data/magnitude? kb24 CFX 0 March 14, 2012 10:42
vibration of a rotating plate in water zhm Main CFD Forum 0 March 2, 2010 18:50
Rotating Stall in Centrifugal Compressors Paul den Held Main CFD Forum 3 October 11, 2000 02:50
