Species Mixing & Combustion
Old   January 31, 2013, 08:20
Unhappy Species Mixing & Combustion
zx9cp is on a distinguished road
Hi all,
I am attempting to assess the effect that fuel/air mixedness have on the combustion characteristics of a gas turbine combustor. I know this is a complex problem and have tried to decompose it as much as possible in terms of method validation.
I have just completed a species mixture validation case (propane stream mixing with coaxial air stream) using a variable composition mixture and got really good results in comparison with experimental data.
I am now looking to validate a simple combustion case using the Burning Velocity Model and have come up against a problem. There doesnt appear to be any information on how to simulate both mixing AND combustion, most studies seem to treat the two in isolation and use a predefined reaction from the reactions list to create the relevant flamelet library.
The main problem I have is that I have conducted my mixture validation by modelling the dispersal of the propane jet using a transport equation howver the documentation stats this should not happen in a reacting case as components modelled using this method will not be considered, evidently not acceptable when it isthe fuel I have modelled in this way.
Can anyone define a method of performing a simulation of this nature?
Thanks,
Chris
zx9cp is offline   Reply With Quote
Old   January 31, 2013, 08:23
Default Bit more info......
Sorry, should also state that this is a Pre-mixed combustion case but I want to simulate the pre-mixing aswell, not just assume a homogenous mixture.
I have trawled the literature and also attempted to work it out for myself based on the ANSYS Non-premixed combustion tutorial but to no avail.
Cheers.
Old   February 7, 2013, 02:18
Default Combustion and mixing
BhaskarD
Magma is on a distinguished road
Send a message via Skype™ to Magma
Try combustion tutorial from ANSYS and study combustion modeling too. That might help.
Magma is offline   Reply With Quote
burning velocity model, cfx, combustion, gaseous mixing
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
Combustion Chamber Species Transport Catthan FLUENT 2 April 27, 2021 03:39
Species Transport and other combustion models in fluent dsn2491 FLUENT 7 January 21, 2020 16:56
PaSR combustion; Species for dieselFOAM and coalChemistryFOAM N. A. OpenFOAM 3 June 17, 2011 03:32
Coal combustion - volatile species Venky FLUENT 4 October 22, 2008 19:28
