Swirl ratio failure in remeshing in CFX
Old   May 4, 2012, 10:27
Default Swirl ratio failure in remeshing in CFX
Ahmet
a_cucen is on a distinguished road
Dear all,
I want to run an internal combustion engine simulation with CFX. I have connected CFX and ICEM-CFD. I have made some analysis so far but after most of the remeshing sections in ICEM-CFD, swirl ratio changes. I have attached a pictures shows this situation. I have tried different mesh sizes, but result is the same. How can I fix this situation?
Regards
a_cucen is offline   Reply With Quote
Old   May 5, 2012, 07:12
The fix is easy - use the IC engine modelling wizard in workbench It uses Fluent as the solver as it has much more IC engine stuff in it that CFX does.
I have no idea what your remeshing problem is. Save a results file before and after a remesh and see if you can spot the problem.
Old   May 5, 2012, 07:29
Ahmet
I have found an extension package that you can use ICE very effectively but this failure happened. The tutorials work fine but when I prepare my simulation like tutorial, it causes this error.
Old   May 5, 2012, 07:31
Have you looked at the flow field immediately before and after a remesh? Do they look the same?
Old   May 5, 2012, 10:05
Ahmet
Yes they look like the same. This failure happens in averadge of pressure in domain. Swirl ratio was one of an example.
Old   May 6, 2012, 06:46
If they look the same then why is the swirl ratio different?
Is the thing which is not carried over smoothly the pressure? That could affect swirl ratio through the density.
Old   May 6, 2012, 07:53
Ahmet
Yes after remesh phase pressure could not been carried over smoothly. It changes just like swirl ratio, so physics of this case fails I think. and It s not depend on mesh sizes or time step sizes. I have not found a solution yet.
Old   May 6, 2012, 20:11
So the problem is the pressure is not being carried over smoothly in remeshes, and the swirl ratio change is just a symptom of that.
Old   May 7, 2012, 03:02
Ahmet
I don' t know. And I haven' t found any solution yet. Really lost in here. Do you have an idea about this situation?
Old   May 7, 2012, 06:59
Other than saying the problem seems to be in mapping the pressure over, no. You will have to do some investigation and try to track it down. Contact ANSYS support if you need to.
Old   May 7, 2012, 14:11
Ahmet
Dear Glenn,
Maybe I can change cfx to Fluent but IC engine modelling wizard in workbench is only modelling cold flow, not combustion. How can I model combustion in this wizard?
Old   May 7, 2012, 17:13
I have never used the wizard so do not know, but I am sure you will be able to include combustion in the model. Fluent has many combustion models.
Old   March 1, 2013, 04:13
Shahr is on a distinguished road
I am sorry that I resurrect this thread. I think I have same problem with pressure field after remeshing. My simulation is not an ICE one though.
My question has been answered previously in here. But I don't expect to have same problem after every single remeshing step.
The velocity field is nicely transferred to the new mesh; The pressure field however has weird mismatching behaviour. Has anybody found a solution for the problem?
Shahr is offline   Reply With Quote
Old   March 3, 2013, 05:08
The thread you quote is talking about initial conditions. This thread is very different - it is about mapping the ersults over to a new mesh and continuing a simulation. This appears to be some problem with the interpolator.
Old   March 4, 2013, 11:11
Thank you for reminding, Mr. Horrocks. I am aware that my previous question was about initial conditions, but if I run the simulation long enough, the pressure will be fixed after some time steps. However, every time remeshing takes place, interpolation (remapping) of pressure field is done wrong, and the same behaviour repeats. This, I believe is similar to the problem mentioned in this thread. You can see this plot from my monitors:
Old   March 4, 2013, 16:28
You will have to do a bit of research your self on this one. Have a look at the pressure field immediately before and after a remesh. Do you see any differences?
Quantifying the swirl in CFX, Swirl Number/Swirl Angle tauqirnawaz CFX 23 July 24, 2016 22:28
CFX Wind turbine mesh trouble and solver failure tallliam CFX 9 April 29, 2012 22:55
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 22:06
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
