ask for help :about cfx turbogrid
Like Tree1Likes
  • 1 Post By captain
Old   March 5, 2013, 01:34
Post ask for help :about cfx turbogrid
captain
captain is on a distinguished road
i want to form a stator .but when i put in the profile ,it gives a warn:
"WARNING
First blade profile is not defined as a hub tip and is too far (0.0945101 of span) from the
hub for reliable surface intersection.Surface extension factor will be adjusted accordingly, however application may become unreliable.
ERROR
Last blade profile is not defined as a shroud tip and is too far (0.858225 of span) from the
shroud for reliable intersection. Must be at least 0.858235 of span. "
i tried some ways ,but can't solve it .Can anybody help me about this question ?thank you!
mahmood-bn likes this.
captain is offline   Reply With Quote
Old   June 13, 2014, 08:14
Default redefine hub coordinates with blade profile at 0% of span coordinates
Véronique Penin
Veronique Pe is on a distinguished road
I think your blade profile at 0% of span is not corresponding to yourhub profile.
Do you try to redefine the hub profile in using the blade profile at 0% of span coordinates? and use 100% of span blade profile coordinates to redefine the shroud coordinates? (plus coordinates to define inlet and outlet domains)
I think my problem is similar:
Surfaces Blade_1_tr_low and Blade_1_sh_tip_rot do not intersect.
Keep me in the loop
Veronique Pe is offline   Reply With Quote
Old   August 13, 2016, 18:56
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
How can I do this or have you solved it?
Ahmed Saeed Mansour is offline   Reply With Quote
Old   April 11, 2020, 08:05
Michael Jeremy
michaelsinaga is on a distinguished road
hey, i know its been a while but have you solved the problem ? i kinda have the same problem. thanks
michaelsinaga is offline   Reply With Quote
Old   April 13, 2020, 23:33
Have a nice time!
Hello dear Michael, it depend on the way you generate the flow path. Have you watched my tutorials about turbomachinery? I avoided these kinda problems by following a specific procedure.
Sometimes it comes from the dimensions of the machine in turbogrid. You have to take a look at them and see if they are identical to the dimensions you want or not. I face this problem before posting my videos on YouTube.
Danke!
Old   October 13, 2021, 05:52
Sar
Subodha
Sar is on a distinguished road
I followed your procedure as mentioned in you tube. I stll get the error. Can you please help me?
Sar is offline   Reply With Quote
Old   October 13, 2021, 05:53
Sar
Subodha
Danke!
i followed this procedure but still get that error. Please help me
profile
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
PhD using CFX Rui CFX 9 May 28, 2007 05:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
