No heat transfer in air
Old   April 17, 2013, 23:07
Unhappy No heat transfer in air
Xiaohu Yang
thomasyangfly is on a distinguished road
Hello guys:
I am doing the numerical simulation using Ansys CFX to simulate natural convection in duct with both ends open. The square duct is put in a big champer filled with air at 25 deg C, and one of the outer surface of the square duct is fixed at constant heat flux boundary (1000W/m2), the other three outer surfaces are kept adiabatic. The air inlet is opening boundary with static pressure at 0 atm and the air outlet is outlet boundary with static pressure at 0 atm. The inner surfaces of the square duct (fluid-solid interface) are automatically set as conservatic heat flux.
After it reached convergence, the fluid has velocity but only the boundary layer of fluid near the inner surface of the squar duct has temperature gradient, the main stream has no heat transfer. I do not know what happened. I tried to check all the mesh (quality is 0.9) and the boundary condition settings, but nothing can I found.
There is a very confusing results: when all of the outer surfaces of the square duct are kept at constant heat flux, there is heat transfer in the main stream. Why with one face kept at constant heat flux, no heat transfer in air?
Could you help me solve this problem? I am suffering this problem for quite a long time. Thanks very much for your kindly help.
thomasyangfly is offline   Reply With Quote
Old   April 18, 2013, 06:35
Can you post an image of what you are modelling and the CCL?
Radiation interface hinca CFX 15 January 26, 2014 17:11
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
Heat Transfer in a pipe flow(hot air) Saima Main CFD Forum 0 January 17, 2011 07:08
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
