How tensor parameters to be entered in CFX-pre?
Old   May 4, 2013, 02:03
Question How tensor parameters to be entered in CFX-pre?
hadi
hadi.iraji is on a distinguished road
hi
I m trying to simulate Flow through porous media and I'd enter the permeability parameter from a tensor.But I do not know how?
(ansys CFX-pre/defalt domaine/porous domaine/porosity setting/permeability)
(for Simulation of Vacuum Assisted Resin Transfer Molding process)
| CFX Command Language for Run |
LIBRARY:
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 0.003356 [K^-1]
END
END
END
MATERIAL: Material 1
Material Group = User
PROPERTIES:
EQUATION OF STATE:
Density = 1300 [kg m^-3]
Molar Mass = 1.0 [kg kmol^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 0.35 [Pa s]
Option = Value
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Transient
EXTERNAL SOLVER COUPLING:
Option = None
END
INITIAL TIME:
Option = Automatic with Value
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 75 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.1 [s]
END
END
DOMAIN: Default Domain
Coord Frame = Coord 0
Domain Type = Porous
Location = B16
BOUNDARY: Default Domain Default
Boundary Type = WALL
Location = F17.16,F18.16,F19.16,F21.16
BOUNDARY CONDITIONS:
MASS AND MOMENTUM:
Option = No Slip Wall
END
END
END
BOUNDARY: in
Boundary Type = INLET
Location = in
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Total Pressure
Relative Pressure = 100 [kPa]
END
END
FLUID: air
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
FLUID: resin
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
END
BOUNDARY: out
Boundary Type = OUTLET
Location = out
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure
Relative Pressure = 20 [Pa]
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 1.185 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = -g
Gravity Z Component = 0 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: air
Material = Air at 25 C
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID DEFINITION: resin
Material = Material 1
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
FLUID: air
FLUID BUOYANCY MODEL:
Option = Density Difference
END
END
FLUID: resin
END
END
HEAT TRANSFER MODEL:
Homogeneous Model = True
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
FLUID PAIR: air | resin
INTERPHASE TRANSFER MODEL:
Option = None
END
MASS TRANSFER:
Option = None
END
END
INITIALISATION:
Option = Automatic
FLUID: air
INITIAL CONDITIONS:
VOLUME FRACTION:
Volume Fraction = 1
END
END
END
FLUID: resin
INITIAL CONDITIONS:
VOLUME FRACTION:
Volume Fraction = 0
END
END
END
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
STATIC PRESSURE:
END
END
END
MULTIPHASE MODELS:
Homogeneous Model = On
FREE SURFACE MODEL:
Option = None
END
END
POROSITY MODELS:
AREA POROSITY:
Option = Isotropic
END
LOSS MODEL:
Loss Velocity Type = Superficial
Option = Isotropic Loss
ISOTROPIC LOSS MODEL:
Option = Permeability and Loss Coefficient
Permeability = 3.5e-10 [m^2]
END
END
VOLUME POROSITY:
Option = Value
Volume Porosity = 0.7
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Option = Standard
OUTPUT FREQUENCY:
Option = Every Timestep
END
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 10
Minimum Number of Coefficient Loops = 1
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
TIMESTEP INITIALISATION:
Option = Automatic
END
END
END
END
COMMAND FILE:
Version = 13.0
Results Version = 13.0
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: acerpc
Remote Host Name = ACER-PC
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = E:\HADI\Ansys CFX\resin infusen robe dayere\robe \
dayere.def
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END
END
END
hadi.iraji is offline   Reply With Quote
Old   May 7, 2013, 04:03
hadi
ANSYS CFX presently allows only K(permeability) to be isotropic ( Ansys CFX help)
cfx
Error while opening cfx file in cfx pre pks126 CFX 9 June 11, 2018 11:00
air ideal gas in CFX Pre wangy1767 CFX 9 October 1, 2012 07:55
CFX Pre Domains for centrifugal pump MechKim CFX 1 September 24, 2012 08:06
CFX Pre Hide symmetry symbols alvid CFX 2 August 15, 2007 11:34
CFX 10 -pre and -post problams on Linux Henry Liu CFX 3 June 22, 2006 06:57
