No convergence method available in ANYS FSI problems? |
May 10, 2013, 07:54 |
Antonio Casas
Rep Power: 12 |
Hi , I canīt add a convergence method on a FSI problem. A pressure solution from CFX fluid analisis is beeing aplyied over a wing shaped structure as a load. When I try to add the convergence method under solution options in mechanical workbench, this option is not availabe.
If I do supress the imported pressure, and add a simple force load on the tip of the wing shaped structure, then this option is available and I can use this convergence method. Can someone tell me why? Thankīs a lot |
May 10, 2013, 08:10 |
May 10, 2013, 08:28 |
Antonio Casas
Rep Power: 12 |
mmm, donīt understand. Why 2 way? iīts 1 way in my case.
thankīs |
May 10, 2013, 08:32 |
Antonio Casas
Rep Power: 12 |
by the way, I see my post have been moved. How to find where? And why itīs beeing moved? I have posted under Ansys forum directory, isnīt the right way to do it?
Thankīs |
May 10, 2013, 23:53 |
Rep Power: 143 |
Sorry, I am no expert on FSI. In fact I will admit that I have never done an FSI simulation with CFX as I do not need to in my line of work But I do know a little about CFD and numerical methods in general and many of the questions asked are simple enough for that.
May 11, 2013, 04:46 |
Antonio Casas
Rep Power: 12 |
Sad for me.
Where can I find help for this? Any suggestion? |
May 11, 2013, 05:14 |
#9 |
Antonio Casas
Rep Power: 12 |
Hi Sijal. Thanks for it.
I do more or less know how to solve a FSI 1 way problem. But as I told you, my problem now is inside mechanical workbench. If I do apply a pressure solution as a load to my structure, I CAN get the stress over it with no problem. However if I try to use the convergence method for a better automatic mesh refinement on the higly stressed areas, this option does NOT show up. Instead, if I do apply a simple force on the tip of my wing shaped structure and supress the imported pressure, the convergence option does show up. Any suggestion? Thankīs |
May 11, 2013, 05:50 |
#10 |
May 12, 2013, 14:39 |
#12 |
Antonio Casas
Rep Power: 12 |
Hey Sijal!
Just downloading right now. thankīs |
force convergence problems in CFX 6DOF rigid body solver | ajay_ks | CFX | 8 | March 25, 2013 04:02 |
Implicit method of FSI | cjtune | Siemens | 0 | March 12, 2003 12:07 |
convergence problems | david aquilina | Siemens | 4 | October 27, 2000 09:18 |
convergence acceleration by preconditioning method | Atit Koonsrisuk | Main CFD Forum | 4 | June 5, 2000 06:21 |
Has the pressure correction method problems? | X. Ye | Main CFD Forum | 17 | September 1, 1999 16:14 |
