show bad cells of dual mesh
Old   May 15, 2013, 03:13
Default show bad cells of dual mesh
tb_cfd
tb_cfd is on a distinguished road
After improving the min angle of a structured mesh in icem i started a simulation. Then i checked the converted mesh quality and determined a min angle which is much worse than in the icem mesh.
Is it possible to see, were the bad cells in the converted mesh are, so that i can improve it?
Thanks for your help
tb_cfd is offline   Reply With Quote
Old   May 15, 2013, 03:18
Yes. In CFD-Post load your def (or cfx or whatever) file. Go to the "Calculators" tab, select Mesh Calculator. Under function select the type of mesh metric you want - in your case Min Face Angle makes sense. Then go back to the outline tab and you now have a variable called Min Face Angle which can be displayed like any other variable. You can do an isosurface to locate the really bad region. Note the new mesh metric variables will be under the puzzlingly titled "..." button.
icem, mesh quality, min angle
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 19:18
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
