Question about setting thermal conductivity in CFX
Old   May 20, 2013, 20:03
Question Question about setting up thermal conductivity in CFX
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
May I ask how to set up the water conductivity to be Cartesian Components instead of only one value for all the directions? I didn't find this option in 'material property'.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   May 21, 2013, 04:53
Ben B. Huang
hwangpo is on a distinguished road
Originally Posted by Anna Tian View Post
use Expressions including coordinate direction.
hwangpo is offline   Reply With Quote
Old   May 21, 2013, 05:15
Question
Anna Tian's Avatar
Meimei Wang
I used:
THERMAL CONDUCTIVITY: Option = Orthotropic Cartesian Components
Thermal Conductivity X Component= 0.6069 [W m^-1 K^-1]
Thermal Conductivity Y Component= 0.6069 [W m^-1 K^-1]
Thermal Conductivity Z Component= 99999 [W m^-1 K^-1]
The error message is
The parameter "Option" in "/LIBRARY/MATERIALorous water/PROPERTIES/THERMAL CONDUCTIVITY" has the value "Orthotropic Cartesian Components". This does not match any of the allowed values: "Value, Kinetic Theory Model, Sutherlands Formula".
How to solve this problem?
Best regards,
Meimei
Old   May 21, 2013, 06:35
Ben B. Huang
maybe that is not reasonable. check it again
Old   May 21, 2013, 06:41
Question
Anna Tian's Avatar
Meimei Wang
The error message shows that there are only three options "Value, Kinetic Theory Model, Sutherlands Formula". There is no option for Cartesian Components.
So it comes back to my initial question. Could you tell me how to set up the water conductivity to be Cartesian Components instead of only one value for all the directions? Could you give an example in which you have achieved the Cartesian Components setting for thermal conductivity?
Best regards,
Meimei
Old   May 21, 2013, 10:20
keeper is on a distinguished road
You did it right. The problem is that it is not supported by GUI. That is why you have error message. So you can suppress this message and run it without any troubles. You work in WB or in standalone? Anyway both options will results in same way. So just supress it and thatīs it.
keeper is offline   Reply With Quote
Old   May 21, 2013, 10:42
Question
Anna Tian's Avatar
Meimei Wang
What do you mean by 'supress it'?
Best regards,
Meimei
Old   May 21, 2013, 11:40
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
I think he means suppress it in the expert parameters.
JuPa is offline   Reply With Quote
Old   May 22, 2013, 03:55
just click with the right button onthose messages in CFX Pre. I deal also with anisotropic conductivity but for solids. I do it exactly like that and it works.
Thermal Via conductivity in Flotherm jitender FloEFD, FloWorks & FloTHERM 3 June 29, 2009 01:57
THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY CARL CFX 1 June 9, 2006 16:44
Viscosity and thermal conductivity Formules CPW Main CFD Forum 3 April 14, 2002 12:40
Inteface thermal conductivity ado Main CFD Forum 4 March 11, 2002 19:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
