June 20, 2013, 16:00 |
wall condensation
Benny
Rep Power: 14 |
I am modelling a cavity that will be filled up by steam. It is a transient simulation with the goal to obtain the cavitys wall temperature over time. The other interesting physic will be the condensing of the steam on the initialy cold walls. therefore I will use the "wall condensation model". But there is something that makes me nervouse. The condensating steam is tracked by a trasnport euqation and another gas (for example) air is uses as constraint to fill up the near wall cells where the steam will vanish. But if I fill up my closed cavity the steam will push out the initial air and therefore there will be no air with increasing time. when the cavity is filled with steam the condensing water should be substituted by steam. but it is not possible to define a steam material as constraint because it can not condense. Am I missundesratnding anything or is the model not suitable for my application? Thanks |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
Very technical question about solving wall boundary layer ... | jlb001 | FLUENT | 6 | December 27, 2014 05:56 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
Quick Question - Wall Function | D.Tandra | Main CFD Forum | 2 | March 16, 2004 04:29 |
