wall condensation
Old   June 20, 2013, 16:00
Default wall condensation
Benny
Benfa is on a distinguished road
I am modelling a cavity that will be filled up by steam. It is a transient simulation with the goal to obtain the cavitys wall temperature over time. The other interesting physic will be the condensing of the steam on the initialy cold walls. therefore I will use the "wall condensation model". But there is something that makes me nervouse. The condensating steam is tracked by a trasnport euqation and another gas (for example) air is uses as constraint to fill up the near wall cells where the steam will vanish. But if I fill up my closed cavity the steam will push out the initial air and therefore there will be no air with increasing time. when the cavity is filled with steam the condensing water should be substituted by steam. but it is not possible to define a steam material as constraint because it can not condense. Am I missundesratnding anything or is the model not suitable for my application?
Thanks
Benfa is offline   Reply With Quote
Old   June 20, 2013, 18:43
You are not defining the simulation properly. Does the cavity initially contain pure steam? Then there is no air anyway. Or is it a mixture of steam and air? You need to know the initial condition.
And as it progresses and steam condenses, what happens? Is the cavity sealed, which means its pressure will drop? Or does air creep in from outside somehow so the proportion of air will increase over time?
You need to be able to define your initial condition and the boundary conditions correctly to model anything.
Old   June 21, 2013, 10:00
Benny
Sorry for not being clear.
Initially the cavity is filled only by air. Then pure steam will be blown into the cavity. the air will be pressed out of an outlet by the steam over time. after a specific time steam will also flow out of the outlet.
I use a variable composition mixture of air and steam in the gas phase. There is an additional homog. binary mixture of the steam and liquid water that takes into account the phase transition by antione eq. The gaseous steam is the transported variable while the air is constraint. But everytime the steam condenses the mass fraction of steam near the wall drops (that is correct) and the missing mass fraction is replaced by air (constraint). so everywhere where condensation occurs I get a "air sublayer" at the wall. but in reality there should be not only air. there should be an mixture of both
Old   June 23, 2013, 06:38
What happens if you model this with steam everywhere, and condensing on the walls? That is, no air present?
Old   June 24, 2013, 09:27
Benny
I will try asap! Then I will have only steam as tranport variable. Lets see what cfx will do if condensation starts and steam vanishes. I will post the message as soon as I get results.
Old   March 10, 2014, 06:39
Default Was it solved?
Patty
ptbs is on a distinguished road
Hi Benfa.
Arriving a bit late on this topic, but I am very interested with this problem of condensation of a phase A (eg water) in a gaz B (eg.air ) along walls as function of temperature and speeds. Moreover, I intend to work in a compressible regime (Ma > 0.2).
Did you solve the problem and could you explain me which solver you used and how you procceeded. Is it a compressible solver? Did you solved heat tranfert? Is there a tuto on this topic or a place to find more info?
Thanks.
Best regards
ptbs is offline   Reply With Quote
Old   July 28, 2016, 14:34
dfranken
dfranken is on a distinguished road
I am looking to solve a very similar problem and was wondering if anyone has solved this problem?
Thanks,
Daniel
dfranken is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 10:44
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
