T junction pipe flows
Old   July 23, 2013, 13:20
Exclamation T junction pipe flows
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
Hello Friends,
I am doing LES of thermal mixing in T junction. I have attached the geometry of the mixing tee used in my lab experiment along with this post. I am trying to numerically validate my experimental results.
1. Instead of using the current experimental geometry which I have attached along with this post, is it ok to use just a completely cylindrical pipe geometry without the complications of my current geometry? Will it alter the flow physics?
2. As far as I have checked, the outer structure of the mixing tee does not affect the internal fluid flow. That is why I am thinking of using just a simple cylindrical geometry which will considerably reduce mesh complications.
3. Also, I am mainly interested in thermal fluctuations in near wall region inside the pipe where the thermocouples are installed and not on the outer pipe structure.
Please let me know if my idea/approach to numerical simulations is correct.
Thank you.
Regards,
Karthick.
selvam2487 is offline   Reply With Quote
Old   July 23, 2013, 16:55
1. Is it OK? That depends on what you are trying to achieve. If close enough is good enough then it is fine. If you are looking for precise answers then no. Yes, it will alter the flow physics but whether it will do so enough to be significant depends on what you trying to get out of this model.
2. Is the outer structure the pipe? Which you intend to do a CHT simulation with? In this case I think it unlikely this is required for a LES simulation and yes, I would consider removing it.
3. The thermal time scales in the solid region are likely to be far longer than the time scales of the thermal fluctuations in the fluid. So if you are interested in the short time scales then the fluid has all the information you need.
les, t junction
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
[GAMBIT] 3D Two pipe T-shape junction mesh Jing ANSYS Meshing & Geometry 8 April 26, 2013 12:27
CYCLIC BC in pipe flows matthias OpenFOAM 0 November 5, 2009 10:52
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
