CFX post
Old   August 28, 2013, 03:50
Default CFX post
bitak
bitak is on a distinguished road
Hello.
I simulated a 3d pipe in CFX
The solver run finished successfully (with all time step).
but when I open the cfx post, I can't see results for different tyime step.
bitak is offline   Reply With Quote
Old   August 28, 2013, 03:55
Default cfx post without results
bitak
At first I set up CFX solver for FSI problem then I change it (I removed the APDL Ansys) and only solved cfx solver for 3d pipe flow. the run finished successfully.
but I can not see result in CFX post.
ERROR
Variable 'Total Mesh Displacement' does not exist on 'wall'.
ERROR
SEVERE
An attempt to recover from a previous error has failed.
The application is likely to be in an unstable state.
I did solver setup successfully.
what i do now?
plz help me...
Old   August 28, 2013, 06:36
By default the results file only contains the result at the end of the simulation. If you want any intermediate time steps you have to add them in the output options, under results file.
How to get reynolds stress values in POST CFX syler3321 CFX 6 January 1, 2017 07:54
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
CFX post - graph kmgraju CFX 0 July 22, 2010 11:59
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
