November 4, 2020, 06:06 |
Cooling Fan
mohamed
Rep Power: 6 |
Hi everyone
I need some regarding a CFD simulation im doing. Im currently using ANSYS CFX to similate a cooling fan on the volute. The boundary conditions are as follows: [*]Analysis type: Steady state[*]material: air ideal gas[*]heat transfer model: total energy[*]turbulence model: SST[*]35000rpm[*]inlet pressure@70C=0.9bar[*]refererence pressure=0[*]massflow outlet=1.3kg/s The interface models are as such: [*]inlet pipe and rotaiting domain: frozen rotor[*]volute and rotating domain: frozen rotor Here is my problem. The velocity contours from the rotating domain dont seem to merge will with the volute however im not sure how to solve this problem. I have attached images to the thread. I would be grateful for any kind of help. Thanks in advnace |
November 4, 2020, 17:00 |
Rep Power: 143 |
The reason is discussed in this related FAQ: https://www.cfd-online.com/Wiki/Ansy...f_reference.3F
November 5, 2020, 03:10 |
Gert-Jan
Rep Power: 27 |
ansys, centrifugal fan, cfd, cfx, fan |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
application of fan in cooling down the engine | michelle | FLUENT | 2 | June 6, 2013 02:47 |
Cooling plates and Fan Curve | akjay90 | STAR-CCM+ | 1 | October 25, 2012 16:47 |
Axial fan or blower cooling a hot object with recirculation | mariconeagles96 | CFX | 4 | April 18, 2012 08:41 |
Cooling fan design algorithm Program | Megatron | Main CFD Forum | 3 | April 15, 2011 15:56 |
