October 14, 2013, 11:29 |
Turbulence parameters and convergence
Rep Power: 17 |
I have observed that turbulent parameters played a major role in the convergence of a simulation. Initially when I simulated with the default values of intensity ans viscosity ratio (5 and 10) the convergence is bad and when I switched over to use intensity and hydraulic diameter (= 4A/P) there is an improvement in the convergence.
Could some one please provide a reasoning to this behavior
Best regards, Santhosh. |
October 14, 2013, 17:25 |
Rep Power: 143 |
Yes, turbulence makes a big difference to fluid flow. I am glad you figured that out
In simple 2-eqn turbulence models the turbulence is modelled to increase the local viscosity (and diffusivity for other equations). This means turbulence is assumed to slow a flow down and make it more viscous - this is in effect a reduction in Reynolds number and convergence is easier in low Reynolds number flows compared to high. (Only up to a point, CFX has great troubles converging for very small Re numbers <<1). |
October 15, 2013, 04:46 |
Rep Power: 17 |
Hi Glenn, Thank you very much for the clarification so when a convergence difficulty is observed with a simulation how is it possible to sense at as an effect of improper or unphysical turbulence settings.
And if a good convergence is acheived by say reducing the viscosity ratio and increasing the intensity of turbulence then is it implied that such turbulence settings represent the real physics
October 15, 2013, 06:00 |
#4 | ||
Rep Power: 143 |
The decision as to whether to choose a laminar or turbulent model only depends on the Reynolds number and whether the flow is turbulent or not. But the choice of which turbulence model to use for a turbulent flow is complex - all I will say is that the SST turbulence model is the best all-round model and use that one unless you have a very good reason to choose something else.
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
Convergence of turbulence transport equations | KK | CFX | 0 | January 31, 2008 20:46 |
Do you know of any tweaks of the solver parameters to accelerate solution convergence | sek | OpenFOAM Running, Solving & CFD | 0 | September 15, 2006 13:45 |
convergence parameters | amv | Phoenics | 4 | September 21, 2005 06:49 |
turbulence convergence | irfan | Siemens | 1 | November 19, 2002 04:38 |
