November 9, 2013, 08:35 |
Torque or moment?
abrahamgx
I am now calculating a HAWT in CFX. I monitor the torque_y()@blade and normal moment on blade(y) in solver manager, where y is the axis. I find that there is difference between them as in the figure.
How does it happen?Which one is the real shaft torque of HAWT? Last edited by abrahamgx; November 10, 2013 at 03:14. Reason: add figure |
November 10, 2013, 04:41 |
Rep Power: 143 |
I am not certain but I suspect normal moment is the pressure force integrated over the surface. It does not include viscous forces. torque_y includes both pressure and viscous forces.
November 14, 2013, 09:21 |
abrahamgx
I wonder which one should I use? It seems that the normal moment which does not include the viscous forces is more consistent with the experimental results.
November 14, 2013, 09:33 |
Max
Your experimental results probably include the viscous forces, so you should use torque_y for comparison if Glenn is right.
November 18, 2013, 11:19 |
abrahamgx
November 20, 2013, 16:39 |
Frank
Rep Power: 12 |
From my experience, CFD Post adds up the normal and tangential moments to get the total moment. The normal component represents the pressure contribution and the tangential component the viscous contribution to the total moment. Specifying an output monitor in CFD Pre as "torqure_y()@location" will output the total moment comprised of both the pressure and viscous contributions.
Rotor Torque Prediction | jason | OpenFOAM Running, Solving & CFD | 7 | August 16, 2016 09:34 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
Torque Converter Pump Torque = Engine Torque? | Torque_Converter | Main CFD Forum | 4 | November 12, 2012 06:44 |
Torque definition | Yali | CFX | 2 | January 7, 2008 03:13 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 06:19 |
