Couple different additional variables
Like Tree1Likes
  • 1 Post By Opaque
Old   February 5, 2014, 13:00
Default Couple different additional variables
TrII4d is on a distinguished road
hey guys,
is there a way to couple two or more additional variables (AV) with each other?
what i want to do is the following:
i calculated heat flux for all three directions (see http://www.cfd-online.com/Forums/cfx...direction.html) with an additional tensor type "vector" ... so i finally got q_x, q_y and q_z ...
now i want to calculate the gradient X of q_x like this :
\frac{\partial q_x}{\partial x} = \frac{\partial (-\lambda * \frac{\partial T}{\partial x})}{\partial x}
but im not able to write an algebraic equation for this case ... the problem is to handle the two gradients ... this is my actual status :
(- Thermal Conductivity * Temperature.Gradient X).Gradient X
but this is not working ...
another idea is that i calculate \frac{\partial q_x}{\partial x} in an AV tensor type "vector" (name GradQ) and use this AV later, i.e.
GradQ X.Gradient X
but this is not working, too ...
any good ideas?
-thanks!
TrII4d is offline   Reply With Quote
Old   February 5, 2014, 14:37
Opaque will become famous soon enough
I assume you got the heat flux vector by doing something similar to
ADDITIONAL VARIABLE: MyHeatFluxVector
Option = Vector Algebraic Equation
Vector xValue = - Thermal Conductivity * Temperature.Gradient X
Vector yValue = - Thermal Conductivity * Temperature.Gradient Y
Vector zValue = - Thermal Conductivity * Temperature.Gradient Z
END
Now you should be able to access the MyHeatFluxVector_x.Gradient X, and any of its components.
NOTICE the syntax to access the components of a vector AV. That is the syntax for AV vector components in the ANSYS CFX Solver. Unfortunately, in CFD-Post you will see MyHeatFluxVector X(Y/Z) instead.
Not sure what you are trying to do with these variables, but if you need them for post-processing only you should be able to do the same in CFD-Post and save you to rerun the case. Create a User Defined variable, and select Vector + Gradient.
Hope the above helps,
TrII4d likes this.
Opaque is offline   Reply With Quote
Old   February 6, 2014, 02:28
hi Opaque,
thank you very very much ... this is exactly what i was searching for ...
i read the syntax for a vector AV in the user guide ... but it was not really clear for me ... but now i got it ...
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
additional variables' effect ariel CFX 9 April 2, 2008 00:41
user SUBROUTINE for additional variables Tuks CFX 0 November 8, 2005 02:09
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
