May 17, 2014, 12:44 |
ERROR #002100048 in Solver
Muhammad Arif
Rep Power: 12 |
This error occur while solving the nozzle flow , I am a bignner can someone tell me how I resolve this issue, Yours suggesion will be highly appreciated, Thanks
" ERROR #002100048 has occurred in subroutine SU_BNEXT. | | Message: | | All vertices for a fluid domain lie on boundaries. This is | | considered to be a fatal error because control volume gradients | | cannot be calculated, leading to serious discretization error. | | | | A common cause for this error is a mesh which is only one | | element thick, without symmetry or 1:1 periodicity on the lateral | | boundaries. If you have this situation, and the domain is | | two-dimensional, please change the lateral boundary conditions | | to symmetry or 1:1 periodicity. Alternatively, for | | three-dimensional simulations, please ensure that your mesh | | has at least two elements across. | | | | Execution is terminating. This error message can be bypassed by | | setting the expert parameter 'boundary vertex check = f', but | | be aware that doing so may lead to sigificant solution error." |
May 18, 2014, 06:34 |
Rep Power: 143 |
The error message is pretty clear, isn't it? It tells you exactly what you need to do.
May 22, 2014, 14:16 |
Muhammad Arif
Rep Power: 12 |
Sorry , I am a bignner, but now a bit learned..
May 22, 2014, 18:42 |
Rep Power: 143 |
OK, let me repeat what the message says:
You cannot have a domain which is 1 element thick. You will need to make it a few elements thick. Note you can have a 1 element thick domain with symmetry and periodic boundaries. But all other types of boundary are not possible. |
May 23, 2014, 14:23 |
Muhammad Arif
Rep Power: 12 |
yes, I got it, Thanks for reply...
May 26, 2014, 02:51 |
Near Wall Mesh Denisty
Muhammad Arif
Rep Power: 12 |
Dear Sir, Can u tell me plz how to increase the near wall mesh density in nozzle ?i am attaching geometry along with some rough mesh.
May 26, 2014, 08:54 |
Rep Power: 143 |
Make the mesh finer. It is a pretty simple concept.
I also note that your mesh has some massive jumps in size. This is bad. You need to transition the mesh when you change size. |
May 26, 2014, 09:46 |
Muhammad Arif
Rep Power: 12 |
Thanks for your reply. Actully I Dont know how to make fine mesh near the wall in ICEM. I want to capture sepration of flow , so need more dense mesh near wall. Plz dont mind , I know I mputting very basic question but I try to that but not succeful yet.
May 26, 2014, 18:27 |
#9 |
Rep Power: 143 |
This is all covered in the ICEM tutorials. You can get them on the ANSYS customer page on the ANSYS website.
August 22, 2014, 15:00 |
#10 |
Hesam Moghaddam
Rep Power: 14 |
Try switching to local parallel run in the CFX-solver instead of serial and the simulation will run without any problem!!!!
Hesam |
September 5, 2022, 02:34 |
Master of Science in Chemical Engineering (process Engineering stream)
#11 |
Ethiopia
Rep Power: 3 |
dear sir, the same message occurred in my simulation please tell me the step how to thick
September 5, 2022, 03:07 |
#12 |
Rep Power: 143 |
I think I have said that before......
September 5, 2022, 03:53 |
Master of Science in "Chemical Engineering PROCESS Engineering stream)"
#13 |
Ethiopia
Rep Power: 3 |
yes, sir, you said it but the response is not clear,i need more explanation, please, how to thick more elemnts
September 5, 2022, 04:59 |
#14 |
Gert-Jan
Rep Power: 27 |
If this is an ICEM problem, then better ask in the ANSYS Meshing and Geometry forum, and add some pictures to see what you try to do.
September 5, 2022, 07:26 |
Master of Science in "Chemical Engineering (Food Engineering stream)"
#15 |
Ethiopia
Rep Power: 3 |
okay thankyou
September 6, 2022, 09:15 |
#16 |
Ethiopia
Rep Power: 3 |
any one can you help me
September 6, 2022, 10:32 |
#17 |
Gert-Jan
Rep Power: 27 |
Your geometry (or at least a part) is 2D. Meaning, you have a surface mesh. In Fluent you can do this, not in CFX. In CFX your 2D part requires an element in the third direction to create a volume. This can be 1 element. Then you can solve your 2D case using CFX with symmetry BC on the front and the back surface.
However, your problem seems not to be in the solver, but in the geometry or in the mesher. So if you don't know how to solve this, then go to the appropriate forum and ask there with some pictures. A picture says more than thousand words. https://www.cfd-online.com/Forums/ansys-meshing/ |
September 6, 2022, 10:41 |
#18 |
Rep Power: 32 |
If you are modeling a 2D case (with one element thick), and you have the wrong boundary conditions on the "2D planes", you will get this error.
The message says clearly, that your boundary condition on those planes can ONLY be symmetry, or translational periodicity using a 1:1 option. If you think those options do not apply to you, you likely do not have a 2D problem and your whole approach is incorrect from the start.
2d cd nozzle |
Fluent Adjoint Solver? | ex10148 | FLUENT | 16 | September 28, 2018 08:11 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
