Gamma- Re Theta Transition Model CFX Roughness Modeling
Old   June 18, 2014, 04:53
Default Gamma- Re Theta Transition Model CFX Roughness Modeling
Prakhar Kapoor
prakhar_32 is on a distinguished road
I have been using ANSYS CFX for my work . I had a question pertaining to the transition model available in cfx and would be glad if you could help me on that.
I am modelling the effects of surface roughness on the flow field in the compressor and for that I define patches of roughness elements in a domain say compressor impeller. My doubt is that if I specify a value of roughness height (geometric) for a patch for which equivalent roughness is specified , then is that value applied to all the walls in the domain. If yes does it effect the flow field despite the fact other walls have no equivalent roughness specified??
Looking forward to your response .
Kind Regards
Prakhar
prakhar_32 is offline   Reply With Quote
Old   June 18, 2014, 06:38
You can define wall roughness to be whatever you like:
* You could split your wall boundary into blades and everything else - then put the wall roughness on the blades only.
* You could make the wall roughness a function of something, maybe radial position. In the radial position of the blades you could write an expression which defines a wall roughness.
Old   June 18, 2014, 07:16
Prakhar Kapoor
Dear Glenn!!!
Thanks for your quick reply. I am really grateful for that. I am also including a picture of my impeller blade with the split patches. What I intend to do is that I want to apply roughness to just patches one at a time, keeping rest of the blade smooth. For that I need to specify geometric roughness height in the roughness correlation field of the impeller domain. My only concern is that, does this roughness height applies to the all the walls or just the wall I have specified as rough with a specific value of equivalent roughness. I got confused because the Manual foe Fluent says that it is applied to all the walls, however there is nothing mentioned in the CFX documentations.
Kind Regards
Prakhar
Old   June 18, 2014, 18:52
Don't worry about Fluent. What ever the Fluent manual says has nothing to do with CFX.
If you set the wall roughness for that wall patch to a certain value then it applies to that patch only. If you do not believe me then do a test and check you get the difference between patches.
cfx, roughness hight, roughness value, transition model
Laminar-to-turbulent transition modelling using SST and SST Gamma Theta models ttu004 CFX 3 June 13, 2014 06:43
CFX transition model issue with VATT PLD CFX 5 April 22, 2014 05:21
menter correlation based transition model (Gamma - Retheta) mb.pejvak Main CFD Forum 0 February 22, 2012 21:39
transition onset - SST:Gamma Theta Model Prad CFX 4 February 21, 2007 09:32
Reynolds Stress Model in Fluent Vs CFX Tim FLUENT 0 December 6, 2005 22:03
