June 18, 2014, 06:07 |
Circumferential Velocity Component
Lars Wein
Rep Power: 13 |
can somebody tell me how to calculate the circumferential velocity from the cartesian components (u,v,w)? I Don't want to use the turbo-mode because I want to use this expression in order to calculate the circumferential components of other flow parameters later on in Post. Thanks a lot and kind reguards |
June 18, 2014, 06:39 |
Rep Power: 143 |
You could define a new coordinate frame.
You could define a new 3D vector variable, and do the transformation from the default cartesian coords to any coord system you like. |
June 18, 2014, 07:10 |
Lars Wein
Rep Power: 13 |
Thanks for your fast replay.
Can you explain this in detail? When I try to define a new frame in post, this is a cartesian frame as well. For the transformation I have the expression v_circumferential=-cos(Theta)* Velocity u + sin(Theta) * Velcoty w (X and Z are my radial axis in the cartesian reference frame). When I compare this to the Circumferential Velocity in the turbo-mode I don't get the same results. |
June 18, 2014, 18:49 |
Rep Power: 143 |
You probably have the equation wrong. Don't forget you also have the axial, circum and radial unit vectors and lots of other ways to calculate it.
July 12, 2015, 05:30 |
meizhenwang
Rep Power: 10 |
Hi
I wonder if you find the method to calculate the circumferential velocity from the cartesian components (u,v,w)。Now I face the same question with you! Thanks a lot and kind reguards |
July 12, 2015, 06:00 |
Rep Power: 143 |
You could define a coordinate frame and get CFX to work it out for you. Or you could do it using some maths. Your choice.
July 12, 2015, 07:54 |
meizhenwang
Rep Power: 10 |
thanks for your replay!
I find only the Cartesian coordinate could be defined in CFX-Post。and can you explain in details of the maths |
July 12, 2015, 08:01 |
#8 | |
Rep Power: 143 |
In the meantime, I will refer you to references like: http://mathworld.wolfram.com/Cylindr...ordinates.html https://en.wikipedia.org/wiki/Cylind...rdinate_system http://tutorial.math.lamar.edu/Class...calCoords.aspx |
July 13, 2015, 10:43 |
#9 |
Edmund Singer P.E.
Rep Power: 20 |
You have another job besides writting responses on this forum? Who Knew!??!!
July 13, 2015, 18:55 |
#10 |
Rep Power: 143 |
It can be difficult fitting paid work in between typing all the posts sometimes.
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
boudary condition for velocity component | ljjouc | OpenFOAM Programming & Development | 3 | April 20, 2014 04:25 |
Solving for only one velocity component | pascool | OpenFOAM Running, Solving & CFD | 2 | February 11, 2013 17:01 |
UDF component in Cyliderical Velocity? | Hongchan Kim | FLUENT | 3 | April 24, 2001 12:20 |
