July 19, 2014, 09:11 |
geometry rotation
nima
Rep Power: 11 |
hi friends,
i'm cfx beginer.i want to simulate this geometry(attached file) in Ansys CFX.those five hole are velocity inlet and that semicircle is pressure outlet and whole geometry rotate about X-Axis with 320mm radius.how can i define rotation for this geometry in cfx. thanks a lot. |
July 20, 2014, 06:19 |
Rep Power: 143 |
I do not understand what you are modelling. Can you show an oblique view? And where you expect the flow to go? And what is rotating and what is stationary?
July 20, 2014, 14:12 |
nima
Rep Power: 11 |
it's kind of turbine blade cooling(impingement cooling)air enter through 5 holes on rectangular surface and after impinge oposite conceve surface exite from semicircle surface.
all of this system rotate about X-axis(axis of rotation and jet axis are parallel). in all of examples and tutorials like fans and rotor etc. we have rotation of solid deal with external flow but in this case i think sth different. i attach another pic. thank you for your attention. |
July 20, 2014, 18:27 |
Rep Power: 143 |
This is simple - just put it in a rotating frame of reference and the rotation will be taken care of. Read up about the different frame of reference models - I think you will find frozen rotor will be adequate and that is a simple easy model to apply.
Have a look at the rotating machinery tutorials for how to set this up. |
July 25, 2014, 04:22 |
nima
Rep Power: 11 |
thank you Glenn. i defined rotating frame in domain, in DM move geometry from x-axis to desired radius of rotation it seems works.
can i see the geometry rotation animation to have sight how does it rotate? i tried but in animation,only shows stremlines or contours and dosn't show the way geometry rotate!! |
July 25, 2014, 06:25 |
Rep Power: 143 |
Frozen rotor simulations do not rotate the mesh. They add the rotation terms to the NS equations so you can use a stationary mesh. If this approximation is valid it makes the simulation a whole heap easier.
August 6, 2014, 00:10 |
nima
Rep Power: 11 |
Hi Glenn.excuse fo my delay.i checked Ansys help,it seems use frozen rotor for external flow like fan and rotor...
how about define rotating in Domain motion instead of stationary in this path(simulation>flow analysis>default domain). |
August 6, 2014, 08:24 |
Rep Power: 143 |
I do not understand your question.
August 13, 2014, 01:46 |
#9 |
nima
Rep Power: 11 |
i mean in cfx-pre,this path in outline tree(simulation>flowanalysis>default domain) define rotating instead of stationary in Domain motion
August 13, 2014, 06:11 |
#10 |
Rep Power: 143 |
If you define the domain as rotating then you either activate the rotational modifications to the equations (if one of the stationary mesh models like frozen rotor) or it rotates the mesh (if transient rotor stator).
If you define it as stationary then the domain is stationary. |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 05:04 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
