Remeshing differents walls with a differents conditions |
August 10, 2014, 14:50 |
Bruno Savio Fichos
Rep Power: 11 |
good afternoon,
I need help to remeshing a disk 3D, like the figure below. And I need make a transient simulation. Boundary walls have the following settings: cfd_online.jpg someone can help me? Sorry about my english. thanks Last edited by brunofichos; August 10, 2014 at 15:01. Reason: the title is more specific now! |
August 10, 2014, 18:34 |
Rep Power: 143 |
I do not understand your question. Meshing a geometry like that should be very easy. Are you trying to do dynamic remeshing? And why have you mentioned moving walls and stationary walls? Are you doing mesh motion?
August 10, 2014, 18:55 |
Bruno Savio Fichos
Rep Power: 11 |
I'm sorry, I did not specify correctly what I do.
First, yes, I'm doing the mesh motion. this is the fluid domain, the left wall is static, and here have a pipe to the inlet flow, the rest is deformable. the right wall rotates about an axis, deforming the rest of the walls. i was clearer now? thanks. |
August 11, 2014, 06:42 |
Rep Power: 143 |
This is easy(ish) to do with mesh motion. You probably do not need remeshing unless you want to use very large ranges of motion.
August 11, 2014, 06:50 |
Bruno Savio Fichos
Rep Power: 11 |
do you have any tutorial? I'm new in ANSYS
August 12, 2014, 21:50 |
Bruno Savio Fichos
Rep Power: 11 |
can any one help me??
August 13, 2014, 06:09 |
Rep Power: 143 |
The CFX tutorials are provided with the software. Have a look in the CFX documentation for the tutorial manual.
August 13, 2014, 07:35 |
Bruno Savio Fichos
Rep Power: 11 |
I've looked at the tutorial, but not found. if u have said that, I will look again.
thanks |
cfd, moving wall, transient |
CFX Remeshing failed ERROR | ashtonJ | CFX | 6 | September 16, 2016 15:41 |
Remeshing with User Defined Options | ChristianF | CFX | 2 | September 24, 2014 09:19 |
ICEM CFD Replay Remeshing | EvaS | CFX | 1 | December 19, 2012 19:30 |
Bugg in Remeshing in 3D - Any Fluent Wizards ?? | Amr | FLUENT | 1 | November 1, 2011 04:04 |
Dynamic Grid Remeshing causing Divergence? | Andrew Wick | FLUENT | 0 | January 23, 2006 18:39 |
