Restarting a CFX simulation from last stop
Like Tree3Likes
  • 1 Post By JuPa
  • 1 Post By oj.bulmer
  • 1 Post By Lance
Old   May 4, 2013, 10:40
Default Restarting a CFX simulation from last stop
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
I am running a transient simulation in ANSYS CFX with a total time of 15 secs and a time step of 0.001 sec. But the wall clock time allowed in my university cluster is 24 hours after which I have to start the simulation from the point where it stopped. I am new to doing transient simulations and do not know
much as to how to do this. Can any one explain me how to do this?
Thanks in advance.
P.S: I searched this forum for a similar thread, but could not find one. I apologise if the same problem is already present in this forum.
Regards,
Karthick
selvam2487 is offline   Reply With Quote
Old   May 4, 2013, 12:55
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
I don't have cfx open infront of me so I'm trying to remember by memory.
If you want to restart from the last timestep and simulation time then:
- in cfx transient settings leave initial time set to automatic
- remove any global initialisation parameters you have set
- go to the solver and before you run the simulation give the .res file from the previous run as the initial coconditions, and make sure you keep the "continue history" check box on.
That should work.
selvam2487 likes this.
JuPa is offline   Reply With Quote
Old   May 5, 2013, 06:41
OJ
oj.bulmer will become famous soon enough
To add to Ricochet's comment, you can use both "res" and "trn" files to resume your solution.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 5, 2013, 07:39
Another thing to consider - you can use the cfx5stop command to stop a run in progress. It will shut down the slover and write a complete results file of whereever it got to. If you want to be clever you can set up a timed job (maybe using cron) to execute cfx5stop just before your time is up. Make sure you give it enough time to complete the timestep it is working on and write the results file.
Old   May 6, 2013, 02:42
Lance
Lance is on a distinguished road
And to add to Glenn's comment there is no need for cfx5stop (and cron) if you use the 'Elapsed Wall Clock Time Control/Maximum Run Time' in Solver Control.
However I've found that it can be a bit unreliable if you are using many CPU cores (>100).
Lance is offline   Reply With Quote
Old   May 27, 2013, 08:04
Balit
oomourad is on a distinguished road
- The first version was released in what year CFX
- What programming language CFX
- What is an advection
- What are the discretization schemes proposed by CFX
oomourad is offline   Reply With Quote
Old   May 27, 2013, 08:17
Lance
Originally Posted by oomourad View Post
what art schem discritisation used by CFX-code
shame on you for breaking almost every forum rule.
http://www.cfd-online.com/Forums/cfx...ease-read.html
http://www.cfd-online.com/Forums/cfx/announcements.html
Have you even opened the manual?
Mazze[ITA] likes this.
Old   September 5, 2014, 09:09
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
That should work.
Hi Ricochet,
what is the problem related to the initialisation parameters? Performing a restart the initialisation should be bypassed, right?
Mazze[ITA] is offline   Reply With Quote
Old   September 9, 2014, 10:45
OJ
I think when you restart the simulation the default option is to initialize from the current results. If you want to initialize from any other results file, then specify its path. But if it is a completely new run that you are after, then just go to Workbench and "reset" the solution tab. Then the initialization will happen from boundaries, that is, fresh run.
Old   September 9, 2014, 11:00
Lorenzo Mazzei
I was referring to the standalone version of CFX, sorry if I did not mention it.
restart, transient
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 17:52
nucleate boiling simulation in CFX Anil CFX 3 August 25, 2010 14:18
CFX steady simulation gharek CFX 1 April 7, 2010 18:41
2D simulation - ICEM meshing for CFX question Ben Makhal CFX 5 April 11, 2007 08:44
Simulation of turbine cascade in CFX. Jonas Pedro Caumo CFX 0 December 9, 2006 13:54
