MAKDIR error
Old   February 5, 2015, 09:17
Default MAKDIR error
Claudia
clau90 is on a distinguished road
I am trying to simulate a reactive flow in a porous medium with varying porosity. My .def file was initially working, but I found that I had to use an opening boundary condition instead of outlet and a smaller time step to improve convergence. However, as soon as I change one of these things, I get the following error:
| Average Scale Information |
Domain Name : Pores
Global Length = 2.4248E-02
Minimum Extent = 1.0000E-03
Maximum Extent = 4.0999E-01
Density = 1.0600E+03
Dynamic Viscosity = 4.3155E-02
Velocity = 8.9544E-02
Advection Time = 2.7079E-01
RMS Courant Number = 1.0368E+00
Maximum Courant Number = 1.1076E+01
Reynolds Number = 5.3332E+01
Slave: 4
Slave: 4 Details of error:-
Slave: 4 ----------------
Slave: 4 Error detected by routine MAKDIR
Slave: 4 CDRNAM = INIT_MFLOIP
Slave: 4 CRESLT = OLD
Slave: 4
Slave: 4 Current Directory : /FLOW/SOLUTION/TSTEP102/CLOOP0/ZN1/BELG6/IP
Parallel run: Received message from slave
Slave partition : 4
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1032
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
I can't find anywhere what this error means. I tried to adjust the memory allocation, but with no improvements. Can anyone help me?
Thanks,
Claudia
clau90 is offline   Reply With Quote
Old   February 5, 2015, 16:16
CFX does have some very cryptic error messages.
I recommend you try this simulation serial. If that works you have a parallel problem. If that does not work you have a problem in your simulation setup. You say you changed the boundary condition type - that sounds like a good place to look for the error.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
