Plotting Radial Velocity and Tangential Velocity in CFD Post
Like Tree2Likes
  • 2 Post By bharath
Old   January 27, 2011, 19:07
Question Plotting Radial Velocity and Tangential Velocity in CFD Post
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Hi all
I applied cylindrical velocity components at inlet of a pipe as inlet boundary condition as below:
Axial Component: 0.175*(1-(r/R)^2)
Radial Component: 0
Theta Component: 0.02*r
I want to plot Radial Velocity and Tangential Velocity along the pipe but I do not know how? I just can plot the Cartesian component of velocity (u,v,w) in CFD Post. Does anyone know how I can plot Radial Velocity and Tangential Velocity in CFD Post?
Best regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   January 27, 2011, 20:23
Bharath kumar
bharath is on a distinguished road
In cfx post go to turbo mode then define your rotation axis next click calculate velocity components.now you can plot the variables you need.
saha2122 and david24 like this.
bharath is offline   Reply With Quote
Old   April 24, 2012, 04:30
Ashkan Javadzadegan
Dear bharath
I did a FSI(Fluid Solid Interaction) modelling in a pipe. In CFD post when I wanted to plot axial, radial and circumferential velocity components, I got this error:
"No data exists for variable "Velocity Axial" specified in object series 1.”
However, I went to Turbo mode, defined my rotation axis and clicked calculate velocity components.
Does anybody know how to fix this problem?
Thanks
Regards,
AshtonJ
Old   July 12, 2015, 08:07
meizhenwang
Jane92 is on a distinguished road
Hi ashtonJ
Have you solved the problem of plotting axial, radial and circumferential velocity components in CFX-Post?
thanks
regards
Jane92 is offline   Reply With Quote
Old   July 13, 2015, 00:53
Ashkan Javadzadegan
Hi Jane,
Try what bharath suggested. You should be able to plot the velocity components.
Old   July 13, 2015, 02:49
meizhenwang
Hi,ashtonJ
In "turbo",first I define a Axial,and then click the " Calculate Velocity Components",an error appears as following
No data types for variable Mesh Velocity Axial
Warning
Action more_vars failed
do you know how to fix this problem?
Radial and Tangential Velocity boundary conditions N. A. OpenFOAM 4 September 2, 2011 07:21
Cylindrical coordinate system - tangential velocity alessio.nz OpenFOAM 2 December 7, 2010 05:07
Axial, Radial, Tangental velocity in FLUENT post Barri FLUENT 2 March 6, 2008 20:29
tangential velocity on a velocity inlet in 2D bretti FLUENT 0 July 3, 2007 08:42
Radial and tangential velocity Antonio Mileo FLUENT 2 February 16, 2001 01:41
