August 31, 2014, 23:50 |
Quantifying Recirculation Region
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I am looking for a method to quantify flow recirculation zone. I have modelled blood flow in several arteries and need to compare the amount of recirculated flow regions in these arteries. If anybody knows how to quantify the recirculation zone, please let me know. Thanks AshtonJ |
September 3, 2014, 06:17 |
Alex
Rep Power: 46 |
The end of a recirculation zone next to a wall is usually defined using the change of sign of the wall shear stress.
July 12, 2015, 21:52 |
Ashkan Javadzadegan
Rep Power: 16 |
Thank Alex.
CFD-Post plots doesn't give you the direction of WSS (WSS values are always positive) Do you know how to determine the direction of WSS in CFD-Post? |
July 13, 2015, 04:25 |
Alex
Rep Power: 46 |
You might be looking at the magnitude of the wall shear stress. In this case a local minimum with a value of zero (or very close to it) is equivalent for intrinsically two-dimensional setups like a backward facing step.
When I was talking about sign change, I was referring to the individual components of the wall shear stress vector where y is in normal direction of the wall. Last edited by flotus1; July 13, 2015 at 05:28. |
what is difference between recirculation region, eddy field and vortex? | fruitkiwi | Main CFD Forum | 14 | January 1, 2021 13:43 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
