December 22, 2015, 17:30 |
Potential use of a porous domain?
Rep Power: 10 |
So I am working on this model working on different types of inlet diffusers to maximize diffusing within the room. I successfully got results like the image with the streamlines. What I did was basically draw these extrudes and then do a Boolean-Subtract. Now, I am working on a semi circle inlet diffuser as shown. However, I would like this to be porous. I would like to see how well the air is diffused if I have a semi circle enclosure with say 50% volume porosity. Do I need to specify a new domain? Do I still do a Boolean subtract? I would rather not be specifying new domains as this is a rather large model and i ran into several issues with the interfacing (ended up not using ANSYS's default interfacer for the diffusers that have worked). Little lost here, help? |
December 22, 2015, 19:03 |
Rep Power: 143 |
Porous regions can be sub domains. They do not need to be an entirely separate domain. But you will still need to define it as a region in your mesh so you can assign it as a porous domain.
December 22, 2015, 19:12 |
Rep Power: 10 |
So extrude it, and dont do Boolean?
What do you mean by "define it as a region in your mesh." I just have a pretty standard mesh (with a bunch of Edge Sizing). |
December 23, 2015, 05:00 |
Rep Power: 143 |
You will need to make it a multibody part with the rest of the domain, and you will probably have to use a boolean subtract. Then when you define the domain put both regions (both the main region and the subdomain) in the domain definition, and make a subdomain with just the porous region in it.
December 23, 2015, 09:01 |
Rep Power: 10 |
Alright, I extruded it just like the photo. Now, I did a Boolean Subtract. Now I cannot select this body when I look for faces in the subdomain selection (Since after a Boolean Subtract that body does not exist anymore?)
December 29, 2015, 14:57 |
Rep Power: 10 |
Alright really need some help here.
How can I do Boolean Subtract AND define that as a subdomain (after a boolean it becomes part of the regular fluid body around it/the cuboid around it)? Is there any way to define the porosity just within the geometry? So the Boolean subtract is just implemented on like 65% of the shape? |
January 2, 2016, 00:13 |
Rep Power: 143 |
Your questions about the boolean subtract are best asked in the geometry and meshing forum.
But to define a subdomain you will need to somehow define a mesh region. You cannot define mesh regions in CFX-Pre. |
January 7, 2016, 14:58 |
Rep Power: 10 |
Is there a way to possibly not use a subdomain or another domain but just use porous material? Like in the geometry?
January 7, 2016, 18:24 |
#9 |
Rep Power: 143 |
I do not understand what you mean. You have to define a region for the solver to apply various physical models. The normal way of doing this is by defining mesh regions.
January 7, 2016, 19:55 |
#10 |
Rep Power: 10 |
Could you please explain how to apply "various physical models"? All I ever learned how to mesh was the entire body at a time. How do I tell ANSYS, "Mesh these faces this way, and the other faces some other way."
Also, how will meshing differently help me model a perf metal/porous material? |
January 10, 2016, 01:08 |
#11 |
Rep Power: 143 |
It sounds like you need to do some meshing tutorials. Have a look at the ANSYS community website, or contact ANSYS support.
January 10, 2016, 13:26 |
#12 |
Rep Power: 10 |
I think what Im gonna do is do "cut material" extrudes and make thousands of pores in the material in the geometry. It seems it will end up being a computationally heavy problem, but no reason why it wont work.
It seems porous domains are really making my interfaces go haywire and I need to input variable properties that I have never heard of before. |
January 11, 2016, 11:40 |
#13 |
Rep Power: 10 |
Haha it is taking 18 hours to converge, and just opening the results file is taking like an hour.
And I havent even done the pattern on all sides yet...too impractical? |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Rotational porous domain | Pifpoffele | CFX | 1 | July 6, 2015 11:46 |
Strange Behaviour of Porous Domain (Pictures Included) | Trev0r | CFX | 0 | April 20, 2015 21:29 |
define porous zone in fluid domain | pannsave | FLUENT | 0 | March 24, 2014 07:27 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
