my residual does not reduced
Like Tree1Likes
  • 1 Post By -Maxim-
Old   April 27, 2016, 10:02
Default my residual does not reduced
yaseen
yaseen wsu is on a distinguished road
hello
my free surface model in steady state, it is residual is greater than 10^-4 for most equations, even I used monitor point for mass flow rate at outlet there are fluctuation. note I used smaller and larger time scale in both cases same thing. can anyone suggest me how to residuals become lower than 10^-4 which is critical
thanks
http://www.cfd-online.com/Forums/att...1&d=1461765708
yaseen wsu is offline   Reply With Quote
Old   April 27, 2016, 18:32
Chen Liu
liucheng8602 is on a distinguished road
Send a message via Skype™ to liucheng8602
There are many reasons for convergence problem.
Please refer to CFX help files about convergence and here is a link http://www.cfd-online.com/Wiki/Ansys...gence_criteria I hope it could help.
I think first you should check if your convergence problem global or local. If it's a local problem caused by the mesh, improve mesh quality. Then please be careful about the turbulence model you selected.
liucheng8602 is offline   Reply With Quote
Old   April 27, 2016, 22:44
yaseen
thanks for your reply
I read this thread before, I think my mesh quality is ok in terms of orthognal and skewness only i have problem in expansion rate due to inflation. i used RNGk-e model, because flow swril and highly curvature
Old   April 28, 2016, 02:39
Maxim
-Maxim- is on a distinguished road
In case you have several domains, display the monitor with residuals for each domain. Also have a look at the MAX residuals and not just the RMS.
You might see that for example "V-Mom in Domain XYZ" has the highest residuals. The go to CFX POST, create an isovolume with V-Mom in Domain XYZ and select "Above Value" and chose 0.001 in case your criteria is 10^-3 for MAX residuals. Choose a bright color. Then evaluate the isovolume (location, size, etc). Maybe take some screenshots for us
Residuals in a steady-state simulations can be high in case there are unsteady flow phenomena like turbulent vortices - the only solution here is to switch to a transient simulation.
gmaschio likes this.
-Maxim- is offline   Reply With Quote
Old   April 28, 2016, 06:27
yaseen
thanks a lot Maxim
no, I have only one domain only I used local parallel divided into 8 partition, thanks for your suggestion, Yes I want to simulate in transient to show how difference between steady or transient. but unfortunately I have residual problem.
Old   April 28, 2016, 07:06
Maxim
you should still display the MAX residuals and create the isovolume.
Old   April 28, 2016, 15:31
yaseen
http://www.cfd-online.com/Forums/att...1&d=1461871657
http://www.cfd-online.com/Forums/att...1&d=1461871671
http://www.cfd-online.com/Forums/att...1&d=1461871682
Old   April 29, 2016, 02:21
Maxim
Invalid Attachment specified. If you followed a valid link, please notify the administrator
Old   April 30, 2016, 06:18
yaseen
the following attachment may be worked, which is isovolume of V-mom for value 10^-3 residual
https://drive.google.com/open?id=0B3...jRKaVF0VU1NZ00
https://drive.google.com/open?id=0B3...DJoeHBhSWlBeXM
Old   April 30, 2016, 09:46
When you attach a file to the forum you then have to do something with it - either make it an image or a downloadable link. It appears you are not doing anything with the attachments you upload and that is why all your attachments are invalid.
Old   May 1, 2016, 01:45
yaseen
isovolume of v-mom for 10^-3 max. residual
https://drive.google.com/open?id=0B3...EdmZGNlYnJVS3c
Old   May 1, 2016, 08:48
Your images are not of the residual. It is just of the velocity.
Old   May 1, 2016, 09:47
yaseen
yes of v-mom velocity which has max. residual, the follow is my residuals
http://www.cfd-online.com/Forums/att...-rersidual.jpg
Old   May 1, 2016, 09:58
I think you have misunderstood Maxim's suggestion. The suggestion was to plot a isosurface of the u/v/w velocity residual (not the u/v/w velocity). This will show you where in the simulation are the highest residuals and this is likely to be the location where your convergence problem occurs.
The equation residuals are not in the results file by default. You have to go to the output tab in CFX-Pre and select the option which adds them to the results file. Then you will have the residuals in the results file as additional variables for you to display.
Old   May 1, 2016, 11:04
yaseen
ohhh, according to your suggestion before running the model, from CFX PRE in output tab add residuals and then after running in CFX POST plot them, otherwise there is no residuals in cfd post. that is right???
Old   May 1, 2016, 20:24
Yes, that is right. You will need to rerun the simulation. Or you could restart the old one, adding the residuals option, and just run it for 1 iteration.
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
