How to determine time step size and Max. iterations per time step. |
January 6, 2019, 13:20 |
Aashi
Rep Power: 7 |
hello every one i want to ask about the thumb rules for setting the time step size and how to set the maximum number of iteration.
like i am doing multi phase analysis how i decide about setting the time step size and maximum number of coefficient loops. Plz reply |
January 6, 2019, 17:53 |
Rep Power: 143 |
The recommendation for most simulations is:
Convergence settings: Min coeff loops = 1 Max coeff loops = 10 Residual and/or imbalance convergence criteria determined by sensitivity analysis Time step settings: Adaptive time stepping, homing in on 3-5 coeff loops per time step. Min time step small enough you never reach it Max time step can be used to stop excessively large time steps if you need to This way the solver finds its own time step, and the time step size it finds is always in the acceptable from a sensitivity analysis. At least I have never seen an example when it is not.
January 6, 2019, 18:54 |
Aashi
Rep Power: 7 |
Thanks for reply sir and your kind consideration. sir how can i perform the sensitivity analysis
January 7, 2019, 05:43 |
Rep Power: 143 |
Sensitivity Analysis: See post #17 on this thread for time step size Sloshing simulation using ansys cfx vof method
cfx |
Time Step Continuity Errors simpleFoam | Dorian1504 | OpenFOAM Running, Solving & CFD | 1 | October 9, 2022 09:23 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
