July 8, 2016, 05:57 |
Naphthalene Sublimation Technique
Yuva
Rep Power: 10 |
Hello Everyone
I am studying the Heat/Mass transfer analogy, I want to validate the mass transfer numerical model against experimental data I would like to know whether CFX can simulate the naphthalene sublimation technique ? Thanks in advance |
July 8, 2016, 06:36 |
Rep Power: 143 |
It depends on what you want to simulate. What are you trying to learn from the simulation?
July 8, 2016, 22:05 |
Yuva
Rep Power: 10 |
ghorrocks Thank you for your help
I would like to simulate a coated surface of solid naphthalene phase on turbine blade and the air free stream to develop a forced mass diffusion of naphthalene vapor in air ... I need to know the depth of the surface of naphthalene that diffused in the air during the simulation and then obtain the local mass transfer coefficient and thus the non-dimensional Sherwood number Thanks again for your help |
July 9, 2016, 20:25 |
Rep Power: 143 |
Wow, I hope you are a CFD expert. You are going to need to be to do a complex simulation like that.
It would be much easier to get these parameters from a physical experiment. Why do it by CFD? You are going to have to validate the CFD against a physical experiment anyway, so what does the CFD add to this? |
July 10, 2016, 19:28 |
Yuva
Rep Power: 10 |
We are studying the Mass/Heat analogy where we can obtain the convective heat transfer coefficient (H) from the mass transfer experiment We already have the experimental results of this analogy, we need to confirm it using CFD
implementation of the technique for turbulent flows DES in openFOAM | Ferdinand | OpenFOAM Running, Solving & CFD | 1 | July 20, 2015 19:11 |
Rhie and Chow Interpolation technique | nsreddysrsit | OpenFOAM | 2 | January 7, 2015 15:35 |
[ICEM] Delnauy technique "Bottom-up" problem | m5edr | ANSYS Meshing & Geometry | 12 | September 8, 2013 08:34 |
Help, Simulation of Sublimation Process using Naphthalene | buzuzu | FLUENT | 0 | December 26, 2010 16:51 |
turbine blade mean line prediction technique | Mahendran.M | FLUENT | 0 | April 25, 2006 03:09 |
