How to skip Molar weight for defining new material |
July 14, 2016, 08:28 |
Omid Shekari
Rep Power: 9 |
Hi
I want to add SN 500/CuO nanofluid as a uniform fluid in CFX. In fluent there was need for 4 specifications which I had. But now in CFX there is an extra "molar mass" value which should be given and I don't have it. Is there any way to skip this? |
July 14, 2016, 11:03 |
Rep Power: 32 |
The answer is NO.
You can workaround by providing a dummy value, say 1 [g mol^-1], but you must beware of how such value is used and if it is relevant for your case. |
July 14, 2016, 11:32 |
#3 | |
Omid Shekari
Rep Power: 9 |
How is it that fluent solves the same problem without this value and CFX can't?!! |
July 15, 2016, 11:41 |
Rep Power: 32 |
There must be some assumption somewhere CFX is not making
July 21, 2016, 16:47 |
Erik
Rep Power: 23 |
Molar mass is only used in certain calculations, like molar fraction, or ideal gas equations. It won't affect other physics/properties if you put in a dummy value. But you have to provide some value no matter what because it requires that input whether it uses it or not.
July 21, 2016, 17:17 |
Omid Shekari
Rep Power: 9 |
Thank you dear friends
Opaque & evcelica |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
