December 1, 2000, 11:26 |
Patch changing along simulation.
Hi everyone,
Is there a way to change the patches along the simulation using CFX? I´m using the 4.3 version and I´m intending to manipulate these patches, say replace a wall with a pressure boundary. I´ve tried USRTPL, but this routine only changes it in the first iteration, not during the simulation. Any suggestion I´d be appreciate. Regards, Fabio. |
December 1, 2000, 15:50 |
Re: Patch changing along simulation.
Hi Fabio,
I guess you have to stop your simulation, change the patch in your *geo/*fc File and restart the job with the saved *dmp File. If you has to do this several times during your run, write a (Perl or Python or...) script for this task. Chris |
December 4, 2000, 05:31 |
Hi Ch.Jung
Thanks very much for your suggestion, but it concerns me the patch changing in a batch simulation, i.e all in one, not dumping files. Regards, Fabio |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[mesh manipulation] CreatePatch | chris1980 | OpenFOAM Meshing & Mesh Conversion | 8 | November 16, 2016 15:44 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 12:46 |
[Netgen] Create boundary | fabrizio | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2008 14:12 |
phase changing simulation | David Liu | Main CFD Forum | 3 | October 25, 2004 01:43 |
