January 11, 2001, 17:05 |
simulating separated flow past the airfoil
Hi all, I am now trying to simulate a flow past an airfoil(NACA 2412) at high incidence angle(> 18 degrees). At this angle the flow should be separated from the airfoil and have an almost constant pressure past the quarter chord. However when I visualize the results using streamline ... there is no separated flow and the surface pressure plot also did not show contant pressure in the separated region. Have anyone tried this with some good results comparing with the experimental data. Could you advise me on the preparation and the turbulence model I have to use and any additional factor that I may have left out unknowingly..
Thanks |
Simulating flow past airfoil with different AOA | ramin | FLUENT | 4 | April 22, 2015 13:09 |
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 17:11 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
simulating an airfoil using a moving boundary | Alejandro | FLUENT | 2 | February 9, 2007 23:46 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
