simulating separated flow past the airfoil
Old   January 11, 2001, 17:05
Default simulating separated flow past the airfoil
Yusoff
Hi all, I am now trying to simulate a flow past an airfoil(NACA 2412) at high incidence angle(> 18 degrees). At this angle the flow should be separated from the airfoil and have an almost constant pressure past the quarter chord. However when I visualize the results using streamline ... there is no separated flow and the surface pressure plot also did not show contant pressure in the separated region. Have anyone tried this with some good results comparing with the experimental data. Could you advise me on the preparation and the turbulence model I have to use and any additional factor that I may have left out unknowingly..
Thanks
Old   January 11, 2001, 17:07
Default using CFX 5.4
Yusoff
I am using CFX 5.4 .
Old   January 12, 2001, 14:49
Default Re: simulating separated flow past the airfoil
John C. Chien
(1). You are dealing with an extremely difficult problem of "turbulent, separated flow from a smooth curved surface", even though it is a simple flow over airfoil problem. (2). Do it from the other end, run a case with incidence angle=60 degree first, to see whether you can get the stalled case from the code.
Old   January 13, 2001, 04:04
Default have some success
Yusoff
Phew .. finally I managed to get the flow separated at 17.9 degrees. The case with 60 degrees is still running though it was not able to converge several times. Hope that this time it will converge. Takes lots of reading the manual and tutorials to get things right.
Thanks for the suggestion anyway
yusoff
Old   January 13, 2001, 20:23
Default Re: have some success
John C. Chien
(1). Well, next time remember to open the parachute when sky diving from an airplane with the wing incidence angle equal to 17.9 degrees. (2). Don't forget about a strong heart too. A happy landing to you.
Old   January 14, 2001, 13:59
Default :) thanks
Yusoff
thanks for your advice ... but probably the aircraft have flaps which help reattach the flow
Old   January 16, 2001, 03:10
Bart Prast
What turbulence model did you use in CFX 5.4?
Old   January 16, 2001, 19:19
Yusoff
I made two runs before obtaining the results. -first run : k-epsilon model -second run : Reynold Stress Model
however for the cfx to be able to solve compressible flow you have to use ideal gas as your fluid not air at stp and choose total energy model.
for more information you could refer to cfx5 manual :
CFX5-solver Physical Models,Fluid Properties and Boundary Conditions in Cfx-5
page 2-11
Simulating flow past airfoil with different AOA ramin FLUENT 4 April 22, 2015 13:09
Airfoil conditions for unsteady flow Dave Main CFD Forum 3 April 24, 2008 17:11
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
simulating an airfoil using a moving boundary Alejandro FLUENT 2 February 9, 2007 23:46
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
