CFX 5.4
Old   February 11, 2001, 16:34
Default CFX 5.4
Zbynek Hrncir
Dear CFD friends, I would like to ask you for some information concerning CFX -5.4. 1.Is it possible to export a volume mesh from CFX to any format readeble in Fluent /patran neutral,nastran,.../. 2.Can I observe convergention with use of any other way rather then by Residuals for example lift force,drag coef., etc.. Thank you Zbynek
Old   February 21, 2001, 16:01
Default Re: CFX 5.4
Pat Neuman
Setting the Expert parameter 'monitor_force' equal to true will output the wall forces to the out file each iteration. You will need to use the definion file editor in the solver monitor to do this (Tools..Edit definiton file)
After running at least one itoration, you can use the File..Export option in the Solver Manager to export to Patran, FeildView and EnSight file types.
Old   February 28, 2001, 01:55
Default Thanks
Zbynek Hrncir
Dear Mr. Neuman:
Thank you for your advice!
Old   March 19, 2001, 22:55
Default Re: CFX 5.4
Dan Williams
Actually, it's monitor forces = t, without an underscore. Here are some other useful ones:
monitor totals = t or f monitor ranges = t or f
monitor totals = t will output the flow balance summary each iteration to the output file. monitor ranges = t will output the minimum and maximum variable ranges.
The solver monitor will not plot these for you in a graph, so you might have to use some other mechanism to graph the data you want.
Dan.
Old   March 20, 2001, 07:04
Default Re: CFX 5.4
Bart Prast
Why is this not mentioned in the manual? We were looking for those.
PhD using CFX Rui CFX 9 May 28, 2007 05:59
Is it a Bug with CFX 5.4 ?? Veebs CFX 5 December 1, 2001 04:38
CFX 5.4 Developing flow Bobby Malone CFX 4 October 3, 2000 23:27
CFX 5.4 cannot restart with 5.3 format Bart Prast CFX 6 September 14, 2000 15:05
cfx 5.4 kinematic diffusivity Daniel Gubler CFX 0 July 20, 2000 03:47
