Composition driven free convection
Prev Previous Post   Next Post Next
Old   May 7, 2001, 18:12
Default Composition driven free convection
P.Fonteijn
Hello.
I am performing CFD-calculations on a case with two connected vessels in which natural convection is important, driven by composition not by temperature differences. Using Rayleigh- and Grashof-numbers, the expected regime is fully turbulent. However, this is only a local phenomena. Far away, but still relevant, conditions are laminar.
The problem I am facing is that the transient calculations suddenly diverge because epsilon becomes small and the turbulent viscosity large (standard k-epsilon). I tried the fully deferred correction but this doesn't help.
Does anyone have experience with such a case? Then could you share some proper settings in terms of:
- convergence criterium (epsilon, velocities?)
- turbulence model (does a low reynolds turbulence model help?)
- grid quality (I know rectangular is preferable but then I will end up with millions of cells)
- differencing scheme (I don't expect any influence)
- anything else (like: number of iterations of a specific equation?)
Every help or suggestion is appreciated, P.Fonteijn.
Free Stream Temperature in natural convection problem tomcatbobby FLUENT 2 January 27, 2011 05:41
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 10:28
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 02:54
Free Convection in STAR-CD George Hampel Siemens 0 November 15, 2000 23:38
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
