what is different of CFX Products?
Old   June 7, 2001, 08:45
Default what is different of CFX Products?
pom
what is different between CFX V5 and CFX TASCflow?
And CFX Products have Pre and post processor?
Regards, pom
Old   June 10, 2001, 11:47
Default Re: what is different of CFX Products?
Dan Williams
First, I'd look at the website carefully. You should be able to get most of the information you need.
As far as numerics are concerned the flow solvers in CFX-5 and CFX-TASCflow are very similar, in that they are both coupled implicit pressure based solvers, and both use algebraic multigrid acceleration. Some differences I can think of betweeen the two are:
- Overall, CFX-5 has fewer physical models. However it has some that TASCflow doesn't, eg. multiphase flow.
- Parallelisation of CFX-5 is far better than TASCflow. Given big enough grids, CFX-5 scales very well, up to 512 CPUs (you would need a huge grid for this).
- The CFX-5 flow solver can run structured and unstructured grids (with a slight memory penalty on structured grids, and the larger penalty of an unstructured grid)
- CFX-5 has a built in unstructured mesher and geometry creation. TASCflow does not have any geometry creation. It does have TASCgrid, but it's pretty tough to figure out, so most people import stuctured grids from other packages such as ICEM Hexa.
Dan.
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 02:54
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
