Comparison between Eulerian and Lagrangian Models
Old   September 3, 2001, 19:13
Default Comparison between Eulerian and Lagrangian Models
Ricardo Damian
Hello People,
I am trying to simulate a 2 phase flow (water & air) and I want to use both models: Euler-Euler (multi-fluid) and Euler-Lagrange (particle transport);
The geometry is as ladle fulfilled with water and there is a gas injection point positioned on the ladle base center. The water was set as turbulent. I am considering the buoyancy effects.
I simulated with both models and I get the following results:
* the shape of the velocity fields are the same;
* the velocity values of the Eulerian case are like 8 times higher than in the Lagrangian case;
* the turbulent quantities (k and eps) for the liquid phase are very larger in the Eulerian case;
I set the same drag coefficient (Cd=0.44) for both phases, as a test, just to be sure that I was using the same value;
The question is, why the velocity values are so smaller with the Lagrangian model?
I'd appreciate you help. Regards,
Ricardo Damian
Conversion of computed velocities in Lagrangian coordinates to Eulerian coordinates SMM STAR-CD 4 June 5, 2011 09:20
lagrangian and eulerian representaions kakollu Main CFD Forum 14 February 12, 2010 11:35
Eulerian and Lagrangian SSS Main CFD Forum 1 February 23, 2007 07:15
lagrangian vs eulerian approach leopoldo luongo CFX 1 June 19, 2006 10:12
Arbitrary Lagrangian Eulerian Methods Soheyl Main CFD Forum 1 June 12, 2006 03:42
