problem in mass flow boundary
Old   November 29, 2001, 02:12
Default problem in mass flow boundary
bapi
hello every one
1.I got a problem. I have fixed the mass flow rate at outlet by mass flow boundary and it is 53kg/sec.after running the program i found that it is 63.85 kg/sec.Why i am getting like this.My problem involves turbulent flow with particle transport and combustion.I am using K-e model with eddy break up model
2.does anyboby has the idea about massfraction1,massfraction2,massfraction3 and massfraction4 in CFX4.4
Old   November 30, 2001, 00:04
Default Re: problem in mass flow boundary
arjun s y
it depends on which model you are using say for eddy break up model ..it solves for
combustionscalar1 is mixture fraction (F) and mass fraction1 is mass fraction of fuel.
arjun
Old   December 3, 2001, 22:47
bapi
Dear arjun
thank you for your reply.Actually I am using eddy break up model for combustion.I did not understand your answer clearly.would you please explain it ?Actually I want 53 kg/sec flue gas from the outlet boundary and I define that as mass flow boundary but I am getting 63kg/sec.thankyou again for your reply
Shakil
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Boundary condition for exhaut flow with imposed mass flow stephane FLUENT 1 November 24, 2011 02:04
mass flow boundary with fractional mass flux specifications ehsan_am86 CFX 2 May 19, 2011 03:02
Mass flow boundary condition vivian Main CFD Forum 0 April 10, 2006 23:32
