creating holes in solids
Old   January 17, 2002, 11:48
Default creating holes in solids
krishna
I am working on cfx-5.4.1 I have to crete a geometry with a hole in a solid(Take as cube with a hole drilled on to one face).This hole does not extend upto the base. Had the hole extend upto full length, I could have made my top and bottom trimmed surfaces and joined by B-Rep. How can I accomplish this task?
Old   January 17, 2002, 20:14
Default Re: creating holes in solids
Neale
I think you can just create an XYZ solid for the cube. Then create another B-rep solid in the shape of the hole, say a cylinder by just extruding a circle and then making two trimmed surfaces on the end. Finally use the cylinder as a "cutout" solid when you make your final B-rep.
Another approach would be to create the entire B-rep from scratch. i.e, make 4 sides by first extruding a square, then a 2 curve surface for the 5th side. Then make a 2 curve surface for the sixth side and turn it in to a trimmed surface (as you mention) with a circle on it. Then finally, extrude that circle to whatever depth you want, and then make a final trimmed surface at the other end of the cylinder. Make the final b-rep by selecting all of the surfaces.
There are probably other ways to do it but these are two of them.
Neale.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to set up meshes of sparse and small holes? leeyee FLOW-3D 1 September 2, 2010 22:50
Flow through multiple holes Matthew Markham Main CFD Forum 3 January 28, 2009 21:47
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
