2d geometry
Old   February 4, 2002, 05:13
Default 2d geometry
Jennifer Haque
Hi everyone,
Does anyone know how I would generate a 2d geometry on cfx5.
Please let me know.
Jennifer
Old   February 4, 2002, 05:45
Default Re: 2d geometry
henry
hi
you can do that but you will need to generate a 3d solid and specify the side walls as symmetric boundaries. that is how it is down in CFX.and you can keep this thicknes as small as you waant.
henry
Old   February 4, 2002, 08:03
Astrid
The following discussions might help:
http://www.cfd-online.com/Forum/cfx.cgi?read=1883
http://www.cfd-online.com/Forum/cfx.cgi?read=1884
Astrid
Old   February 4, 2002, 13:51
Robin
Hi Jennifer,
You can switch the mesher to a 2D mode. Check out this FAQ for details. http://www.software.aeat.com/cfxcomm...ail.asp?id=527
Regards, Robin
Old   February 4, 2002, 18:07
Neale
2D problems in CFX-5 are solved by:
1) Creating a mesh with a single layer of 3D elements.
2) Defining the transverse boundaries as symmetry planes.
You have 2 options for grid generation in CFX-5:
1) Switch the mesher into 2D mode. See the posting by Robin for more details on that.
2) Use the native patran meshing tools in CFX-Build. You have to start Build in meshing only mode, and then select the patran mesher from the Tools menu I think?? I can't recall exactly. It's really easy though.
Neale.
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
