geometry file problem
Old   February 28, 2002, 12:02
Default geometry file problem
a.melandinos
I have built a model with a file name prototype3.db by using the mesh build, and my problem is that I can not find the geometry file related to that prototype3.db. (What I know for sure is that it has an extension *.geo) Does CFX4.3 creates the geometry file automatically? If yes, where does it store it and with what file number?
Old   February 28, 2002, 17:41
Default Re: geometry file problem
cfxbeginer
meshbuild make the file *.geo. it will be m01.geo when there is not other *.geo file. The form is m+number. You can find that the file with lastest number is your file that you just create.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem when I try to write the geometry file massimo Siemens 0 January 14, 2003 04:58
