Large Atmospheric Model
Old   June 28, 2002, 03:01
Default Large Atmospheric Model
Rhydar
Hi all, same problem different day. I am trying to model the effect of a very large solar collector on the atmosphere. I need a computational field of about 5000m squared. 20x20x20 control volumes. Due to the height of the model, it is fully compressible, pressure boundaries on the top and sides to emulate DALR temperature and pressure. At the moment I keep the viscosity high in order to run a laminer solution. Problem is stability and accuracy at any computational field above 100m, divergence and induced velocities. Does anyone know the trick about atmospheric modelling with CFX 4.4????? Any help will be greatly appreciated!! Regards
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
problem in large scale model limingtiger Siemens 0 July 30, 2005 03:59
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
