April 7, 2010, 08:24 |
CFX steady simulation
Gareth
Rep Power: 16 |
Hi CFD users,
I am rather confused by the steady simulation in CFX. I'm using CFX 12.1. As far as I know, when assuming steady conditions, all the D(phi)/Dt terms are set to be equal to zero. Why is there a time step in CFX steady simulation? So, if I am solving an unsteady and/or turbulent flow by assuming steady, would I get my residuals as fluctuating or divergent? As far as I know from Fluent, there is no such timestep used for steady calculations. Thanks for any advice. |
April 7, 2010, 18:41 |
Rep Power: 143 |
This is all explained in the documentation. The solver takes a psuedo-time stepping approach to convergence. Many other solvers take a under-relaxation approach to convergence and hence no time step is required - but you need to set under relaxation factors instead.
In CFX it is psuedo-time stepping as not all the transient terms are included and different equations can be advanced at different rates. |
Small cluster configuration for pump simulation at CFX | Nevel | Hardware | 2 | April 7, 2014 06:07 |
steady simulation | Rogerio Fernandes Brito | CFX | 5 | August 9, 2008 20:22 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
mesh from Workbench Simulation to Cfx Pre? | Dai | CFX | 6 | November 11, 2006 12:19 |
