CFX-Analyse on WinXP
Old   July 20, 2002, 01:45
Default CFX-Analyse on WinXP
Luis Rojas-Solorzano
I know CFX4.4 is not intended for WinXP platforms, however, I installed it on my newer laptop running XP and everything worked fine, except for Analyse which does not run. When I try to run it, it kicks me off and the environment windows says: " This applications has requested the Runtime to terminate it in an unusual way. ..."
I'm running on Exceed 6.1, which also might be the reason of the problem.
Before I buy the Exceed 7.0, does anybody have dealed with this problem already? and, if so, how have you handled it?
All the help will be greatly appreciated, before I have to migrate to Exceed 7.0 and/or from XP to Win2000 or NT4.0 which are supported by the software, but it has so many inconveniences trying to find out the drivers for the laptop that you know ...
Regards,
Luis
p.d.: On the other hand, since View in now not supported on CFX, how do you generate a PLOT3D file out of the dump file to introduce it, let's say into TECPLOT? Thanks again.
Old   July 22, 2002, 15:17
Default Re: CFX-Analyse on WinXP
Ribeiro
Hola, Luis
I'm affraid you have to change your Unix emulator to Exceed 7.0. This version is required to w2k. Thus I believe that this requirement is the same for XP. I have run CFX in XP but just once. I cannot say that it could work always.
good luck. Ribeiro
Old   July 22, 2002, 18:43
Ribeiro, thanks for your advise. I'll be doing some adjustments during the next days, and one of them will probably be upgrading to Exceed 7.1. I'll let you know if it works. Regards,
Luis
Old   July 23, 2002, 03:38
Sheepish
It may be worth checking out the CFX Community pages for such info, as upon just checking, it says that Windows XP platforms are fully supported for CFX-4.
Old   July 27, 2002, 08:07
Good News. I've just installed the Exceed and Exceed 3D ver7.1, and Analyse started working on Win XP.
Thanks,
Luis
Cannot start CFX 12.1 on WinXP Pro Udio_NT CFX 2 June 18, 2010 07:10
PhD using CFX Rui CFX 9 May 28, 2007 05:59
how CFX output into tecplot to analyse? prayskyer CFX 5 July 19, 2006 20:32
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
CFX Analyse James Hart CFX 3 January 25, 2001 19:38
