Outlet -> Inlet How?
Old   August 3, 2002, 06:12
Default Outlet -> Inlet How?
lego
Hi!
I could not find in the manual, that how to save a 2D region of a result, and set it as boundary condition for the next problem with CFX-5.5.
Specially, I would like to set an outlet velocity filed result of a previous run as inlet velocity in my present run.
Thanx
Old   August 5, 2002, 16:55
Default Re: Outlet -> Inlet How?
Satya
Hi Lego,
you can export the data of velocity field on outlet BC to a file in CFX visualize.There is an option called CLOUD INTERPOLATION in expression editor where you can import this data file and apply as inlet velocity BC in the next run. You can find about it in the CFX-basic functions manual(pages 280 - 286). Hope this would help you.
satya
Old   August 13, 2002, 12:23
lego
Thanx!
It works correctly!
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
Boundary conditions: inlet and outlet aline OpenFOAM 7 June 29, 2010 03:45
Inlet but not outlet mireis FLUENT 1 June 10, 2010 10:56
Duct Flow with 90 degree inlet and outlet k FLUENT 3 August 19, 2007 14:30
one inlet and two outlet Fluenter FLUENT 2 March 28, 2004 23:23
